I got the following parts for free. What I want to know is will it even be worth using these parts to build a HTPC or even a gaming PC? If it does end up being worth it, can you tell me what would be the best ram and gpu to add to it at a price to performance ratio. I have a couple hard drives lying around I can throw into it. I am wanting to keep the total price as low as possible just because I want to see how good of a HTPC I can get for as cheap as possible. Scrapyard wars gave me this idea and turns out my dads work has like three giant card board boxes of old computers that get recycled once they fill up. So my dad got permission to let me scrummage though it and this is what I got. Thank you for the help!
Parts I Got:
http://pcpartpicker.com/p/8g2dpg
Cooler Master 700W PSU
Intel Core 2 Quad Q9650 3.0 Ghz
Intel DP45SG LGA775 MOBO
I also got a Cooler Master N300 ATX case that all these parts came in. (Missing a side panel)
https://linustechtips.com/topic/556375-retro-build-kinda/
Old parts modern case?
Just grab as much RAM as it can fit and you could turn it into a media NAS, throw all movies and what not on it.
https://linustechtips.com/topic/556375-retro-build-kinda/#findComment-7328907
Just now, bcn0515 said:
is there even a possibility to make it a gaming pc?
You could, possibly, the CPU isn't too bad, but that probably isn't worth it.
https://linustechtips.com/topic/556375-retro-build-kinda/#findComment-7328925
My rig: r7 1700 @ 3.9/1.35v, 16gb ddr4 3200, assorted rando SSDs, hx 1050, vega 64 1650/1025
MY $75 BUILD https://linustechtips.com/main/topic/576889-the-75-build-log/#comment-7547280
https://linustechtips.com/topic/556375-retro-build-kinda/#findComment-7328948
