I plugged my UsB Flash Drive (Sandisk Cruzer Edge 16Gb) to a local Internet cafe near my school. I did some shits. then at home when I plugged my Flash Drive to my computer it is Write protected. I can take stuff from the drive but i can't Edit or put files on it. I can't Even Format the Fucking thing. I tried solutions like editing the registry and CMD
but none of these works.
Can someone help me?
Is there a Program that can disable this "write Protect"?
Thanks :D
OS: Windows 10 Pro 64 Bit
https://linustechtips.com/topic/556338-write-protected-usb-flash-drive/
Thanks :D
try disk management
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
computer management > storage > disk management
or just use mini partition wizard
both give you more options than file explorer
                   _/ V\
    ______|   __/_/| |
1 hour ago, Pride Chicken said:
the format option is greyed out...
This is what a quick google search got me, maybe 1 of these methods will help.
http://www.pcadvisor.co.uk/how-to/storage/how-erase-write-protected-usb-drive-or-sd-card-summary-3633096/
Core i5 6600k | Gigabyte GTX 970 Windforce | MSI Z170 Krait Gaming Crucial Ballistix Sport 16GB DDR4 2400 | NZXT S340 Red                                              EVGA SuperNOVA 750 G2 | Coolermaster Hyper 212 Evo | Razer Blackwidow Tournament | Logitech G600 Razer Kraken USB        If you want me to see your post, please remember to quote me!
it's possible that due to many crapped out cells in the NAND flash, the drive entered read only state to preserve existing data - it's quite common
if you have personal data on it, smash it with a hammer
if you don't and it's still under warranty, RMA it
Ive tried all of these but none of them work... anyways thanks man!
sad..
