1) I would assume so, but I'm not 100% sure
2) Being an owner of a normal Enthoo Pro, I think it's fantastic and that Phanteks makes the best cases currently.
PCPartPicker link: http://pcpartpicker.com/p/R6GTGX
Привет товарищ ))))
https://linustechtips.com/topic/556094-phantek-pro-m-question/#findComment-7325975
31 minutes ago, GeorgeKellow said:
Can a hyper 212 evo fit in it?
Also, whats your opinions?
it does fit and it's an AMAZING case for the price my friend has one and i recommend it all the time on the forum...it's better than the S340 and shit like that.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/556094-phantek-pro-m-question/#findComment-7326138
