cooler master hyper d92??
The hyper 212 has been a solid cooler for a long time. Depending on what CPU your running you can easily get a solid overclock on it. If your building on a budget the Hyper 212 is the best air cooler under $35 and you could make an argument for it being better than most air coolers under $50.
https://linustechtips.com/topic/555745-cooler-master-hyper-d92/#findComment-7322735
14 hours ago, yasas326 said:
I was drawn to d92 mainly coz of its looks. so your suggestion is to go for 212. thanks:)
Yeah, I would get a hyper 212 evo or x. The Hyper D92 is a tad expensive for its performance, but it does look really pretty. I only bought one because it was one of the only affordable coolers (Noctua was too expensive) that would fit in my 4U chassis with my motherboard (I tried the Hyper 212...it wouldn't fit).
https://linustechtips.com/topic/555745-cooler-master-hyper-d92/#findComment-7326067
