Hey guys, just curious on if anyone with a 4690k has issues with heat?  I am running it with a stock cooler, and i know im not going to get great temps, but i was playing fallout 4 for about an hour or so, and i hit 93 degrees Celsius... im going to watercool it here soon.  Should i avoid playing games until then? Am i damaging my cpu? thanks for any input
https://linustechtips.com/topic/555738-4690k-is-hot/
Double check the heat-sync and paste. Sounds like a bad connection between the two.
If not that, try toning down the quality of the game.
GIGABYTE Z97MX-G516GB DDR3 | I5 4690k @ 4.4ghz | 1TB SSHD, 500GB HDD, 128GB SSD | GTX 1070 8GB | Corsair Graphite 230 | EVGA 650W | Hyper 212 EVO
Cinebench R15: 636(all cores), 127FPS
https://linustechtips.com/topic/555738-4690k-is-hot/#findComment-7322678
A 4690K? Everyone knows Intel cpus suck and get very hot. You should get an FX-9590. It's far more powerful and runs at nice fresh temps.
https://linustechtips.com/topic/555738-4690k-is-hot/#findComment-7322705
2 minutes ago, huffislost said:
i dont have any thermal paste:( could i just try re setting the cooler? or will i screw it up more if i dont have paste
While it probably wouldn't screw it up, I wouldn't recommend it, because if something happens you can't re-seat the cooler. The devil canyon cpu's have been known to run hot, just how people talk about hitting the silicon lottery, there is a flipside to that. Not to mention Fallout 4 does use more of the cpu than most games so maybe turn the settings down until you can get a better cooler.
https://linustechtips.com/topic/555738-4690k-is-hot/#findComment-7322711
51 minutes ago, huffislost said:
arma 3 i got up to 80 degrees, i play fallout on ultra so that could be it?
Try running a cpu stress test like aida64 or similar and see what your temps get to after letting it run for a while.
Core i5 6600k | Gigabyte GTX 970 Windforce | MSI Z170 Krait Gaming Crucial Ballistix Sport 16GB DDR4 2400 | NZXT S340 Red                                              EVGA SuperNOVA 750 G2 | Coolermaster Hyper 212 Evo | Razer Blackwidow Tournament | Logitech G600 Razer Kraken USB        If you want me to see your post, please remember to quote me!
https://linustechtips.com/topic/555738-4690k-is-hot/#findComment-7322923
