Liquid freezer 120 (PC overheating)
Solved by Ryoutarou97,
5 minutes ago, sissj said:You might want to remove the cooler heat sink from the CPU and see if the thermal paste has spread properly, It would also be that the watercooling pump may have failed.
Listen to see if the pump is working or check to see if the air coming from the rad is warm to test that. If not, did you OC it and if so, how high?
Featured Topics
Skelitor ·
Posted in General Discussion3 -
3
Sir Judgementz ·
Posted in General Discussion0 -
Rmooney193 ·
Posted in Troubleshooting1 -
2
8
