3 minutes ago, Digital_ said:
You start inserting on the side that doesn't click and then pull the tab and press lightly down until it click back into place. Not all of them have two sides of I guess "clamps" you could call them.
But only 1 side is in the other side is half out
https://linustechtips.com/topic/554502-motherboard-help/#findComment-7309465
