I had a budget build geekgasm today. I'm not made of cash and wanted to upgrade my old GPU (560ti). I got a EVGA Gforce GTX 960 card for 100.00 delivered. Anyway what steps do I need to take driver wish to switch old card to my new awesome card (at lease for me)?
I recently upgraded from an 650ti to a 970. As soon as I put it in, turned on my comp, I saw GeForce Experience recognized it and could play from the get-go.
As long as geforce drivers are up to date, you should be good. Make sure you put it in while the computer is off!
Not sure what you are asking? If you are asking for the best way to install new display drivers, use DDU.
CPU: AMD 5950X    MB: Asus ROG Crosshair VIII Dark Hero    RAM: HyperX Predator 64GB    GPU: Nvidia RTX 3090 Ti FE    SSD: Seagate FireCuda 530 2TB
PSU: EVGA 1200w P2    COOLING: EK AIO Elite 360    CASE: Fractal Design Torrent
   DISPLAY: LG CX48 4k OLED    AUDIO: HIFIMAN Arya SE
8 minutes ago, Kickflapper said:
do I need to uninstall old drivers first?
Yes, run DDU in safemode.
http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
