Help with GPU
Solved by Kryptyx,
59 minutes ago, paps511 said:I'm not sure if a 960 can run 3 monitors including a 4k monitor. I would suggest at least a 970, but more realistically a 980 or a 980Ti.
You don't play games, but do you think you would in the future? If there is a possibility for this, get a 980 and that will cover you to play most current games at 4k on High (not ultra)
No no no....
That is way WAY overkill for non-gaming 4K. You can push 4K desktop support on modern integrated GPUs... 960 is even overkill. 950 would do but I'm sure someone else can point you to something even cheaper.
