4 minutes ago, XTREMExFTW said:
Hi guys, my lens wobbles when I touch it or apply pressure, this is an issue as I use manual focus and the lens in question is the Nikon DX AF-S Nikkor 18-55mm any help is appreciated. Thanks!
That's normal for kit lenses.
Primary Build: i7-4790 · 16GB Hynix DDR3-1600 · Sapphire Tri-X R9 390x · NZXT S340 · Win10 Pro · Seagate Barracuda 1TB T_T
Portable: 2015 Retina Macbook Pro 13" · i5-5257u · 512GB PCIe SSD · Intel Iris 6100 T_T
If my post helped you, please rate it!
3 minutes ago, XTREMExFTW said:
Really? It wobbles maybe a cm and a half... I was just concerned about it.
In and out? How does it wobble? 1.5cm is not normal.
1 minute ago, XTREMExFTW said:
Not in and out, sideways and maybe I exaggerated a bit for the measurement, maybe 1.1cm at most.
You may want to file a warranty claim if you're still in warranty (probably not).
Does it affect focusing? Since it's side-to-side I don't think there should be an issue, even if there is you could just get a newer 18-55 and use the current one as a tilt-shift.
No it isn't under warranty as it a old camera, and it affects focusing by making screeching noises and it doesn't focus as well as it did, this started about a month ago.
I can only say get a new one. Kit lenses like that are notoriously hard to fix.
They're also pretty cheap - maybe upgrade to a Tamron 17-55 f/2.8.
1 hour ago, Supercian411 said:
try peanut butter
wauwo such helpfuls
