Hey guys i buy a be quiet! rock 3 and i want to instal it the side of the text, to push the hot air exit on the top of the case.
Is that gonna be a problem ?
Why every body push hot air in the back and not on the top ?
Why be quiet but the text this side if we should push air on the back of the case ?
What do you think ?
https://linustechtips.com/topic/553957-be-quiet-instal-side/
You can blow air out the top if you want, it makes no difference.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/553957-be-quiet-instal-side/#findComment-7303199
What do you think ?
As long as it securely mounts you're fine.
And we mostly use front -> back systems so that you can have versatility, it can be placed on carpet w/o worrying about not taking in air, stuff like that.
Personally, I'm cooling my home gaming rig with front -> back, and my lan rig is cooled from top -> bottom.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/553957-be-quiet-instal-side/#findComment-7303206
