Hello,
First, i'm sorry if this is the wrong section.
Just finished my build without a VGA at last saturday. Everything okay and running fine without issues. Today when i turned on this problem on video was happening. Already removed memory sticks and tried running with only 1, removed cooler and processor and installed again, graphics drivers, etc...
The problem (happens everywhere: windows, games, videos, etc):
I dont think its bent pins since it started working fine. Just don't know what else to try.
Specs:
ASUS Maximus Hero VIII
Skylake i7 6700k
Corsair H110i GT
4x 8Gb Kingston HyperX Fury 2666Mhz
EVGA P2 1000w
Thanks in advance :)
https://linustechtips.com/topic/553895-6700k-hd530-problem/
check the refresh rate and make sure it is using 60Hz
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/553895-6700k-hd530-problem/#findComment-7302487
Otherwise, maybe check the cable itself? I've seen bad HDMI cables do some wonky stuff when I was using my TV.
BRRRT!
PC
  • ASUS TUF GAMING B550M Plus
  • Ryzen 5 5600X undervolted
  • Gigabyte VISION OC RTX 3070 undervolted
  • 32GB Teamgroup Dark Alpha 3600 MHz CL18
  • Corsair TX750M
  • Fractal Design Meshify C Mini
Sim Equipment
  • Logitech Extreme 3D Pro & Thrustmaster TWCS Throttle
  • Logitech G27 with pedals and H-shifter
  • TrackIR 4
https://linustechtips.com/topic/553895-6700k-hd530-problem/#findComment-7302881
9 hours ago, blueballs said:
this is dope, could be directly your screen...
Yeah, didn't changed the monitor yet.
Checked, and its 60Hz.
Tried another HDMI cable and nothing change :(
https://linustechtips.com/topic/553895-6700k-hd530-problem/#findComment-7304288
Try a different monitor. If everything else works fine, biggest chance of the screen slowly dying.
CPU: AMD Ryzen 9 5950X PBO GPU: Asus Strix RTX 3090 OC Mobo: Gigabyte X570 Aorus Master RAM: 32GB G.Skill Trident Z RGB 3600Mhz CL17
CPU Cooler: Corsair H150i Capillex Storage: Samsung 980 Pro and 970 Evo 1TB Samsung 860 EVO 1TB Crucial MX300 525GB WD Black 2TB PSU: Corsair HX1000 Case: Corsair 500D SE RGB 6x LL120
https://linustechtips.com/topic/553895-6700k-hd530-problem/#findComment-7304678
Also, try the Display Port if you can. I have a GPU which has a faulty HDMI port, causing all sort of graphical glitches due to poor contact.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/553895-6700k-hd530-problem/#findComment-7304948
Yeah, i will try with another monitor later when i come home
I will try to get a display port cable to test. I don't have one
https://linustechtips.com/topic/553895-6700k-hd530-problem/#findComment-7305825
