driver problems plz help :)
Solved by NeoFrux,
Windows 7 is 6 years old now, so it's not surprising it doesn't have the drivers for a brand new build. You'll need to either use the driver disc that came with your motherboard, or if you don't have an optical drive, you'll need to go to your motherboard's support page and download the drivers onto a USB stick instead to transfer over to the new PC.
PopsicleHustler ·
Posted in Audio1 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
play_circle_filled
Latest From ShortCircuit:
