As long as it's in a PCIE 3.0x4 or higher and the lanes are supplied by the CPU and not the chipset then it doesn't really make that much of a difference which slot you use.
Yes, capping the framerate/vsync can often prevent coil whine. As for moving the GPU to a lower slot...well, maybe it's possible on some boards...depending on where the coil whine is coming from/why.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/553573-coil-whine/#findComment-7298562
how do i know if they are not supplied by the chipset?
https://linustechtips.com/topic/553573-coil-whine/#findComment-7298566
What motherboard do you have? (if the slots are x16 slots that aren't wired for x4 then it's from the cpu -- assuming the board doesn't have a PLX chip, which only top tier flagship boards have)
PSU Tier List | CoC
https://linustechtips.com/topic/553573-coil-whine/#findComment-7298568
http://pcpartpicker.com/p/3K3ZsY - the /U 3.1 , it isn't that model, it's just a x99 deluxe
You can use whichever slots you want, I just wouldn't use the very bottom slot as it shares lanes with M.2 slot.
PSU Tier List | CoC
https://linustechtips.com/topic/553573-coil-whine/#findComment-7298586
3 minutes ago, MarkoCroatiaMC said:
umm... the m.2 slot is near the ram slots. on x99-a and x99-pro it's down near the 4th pcie lane
I know where it is. The 5th PCIE x16 slot still shares lanes with the m.2 slot.
PSU Tier List | CoC
https://linustechtips.com/topic/553573-coil-whine/#findComment-7298597
