GHz speed
Solved by Mixzzz,
1 minute ago, Assassin56 said:I have a amd FX 8350 cpu in my new desktop. it is supposed to run up to 4 GHz and its running at 1.32. how do i increase the GHz speed.
It's in idle...When you put on some load it will ramp up to 4.0GHz(4.2GHz if you turbo enabled)
HunterSVK ·
Posted in Troubleshooting0 -
Ozzi ·
Posted in Networking0 -
1
MadManMarsBar ·
Posted in Build Logs0 -
IAmAndre ·
Posted in New Builds and Planning3 -
4
2
Playgb2 ·
Posted in Troubleshooting1 -
2
1
play_circle_filled
Latest From ShortCircuit:
