Just now, Arixl said:
I only use my ear phones for music on my phone, i'v gone through 3 pairs they either just break or sound like garbage, i'm hoping to get a pair that is high quality as far as phones go, nothing ridiculously over priced, thanks!! <3 <3
  Hide contents
What's your budget?
https://linustechtips.com/topic/553272-ear-phones/#findComment-7295773
$80 is not a lot of budget for a long lasting pair of quality headphones. I'm assuming you will use them out and about so you will want to go with closed back so you don't disturb others around you. Another option might be to consider picking up some quality in ear monitors (earbuds). These for example sound great and are just over half of your budget. http://www.amazon.com/Harman-Kardon-AE-High-Performance-Headphones/dp/B00A3R3T1C/ref=sr_1_1?ie=UTF8&qid=1456198845&sr=8-1&keywords=harmon+kardon+ae
浪速の建てるは静か用に建てました!- Build Log Coming Soon!
https://linustechtips.com/topic/553272-ear-phones/#findComment-7295796
1 minute ago, Hydrogen1803 said:
From $15- $30 you can get a good pair from Sony at best buy. I also like what House of Marley has, which I recommend: http://www.thehouseofmarley.com/headphones/in-ear-headphones.html
I'm from Aus, don't have best buy here =[ and the cheapest pair on that site is out of stock other ones are like $120
https://linustechtips.com/topic/553272-ear-phones/#findComment-7295800
Yea i guess i'll have to go on amazon and look at similar rated ear phones, the only ones that are sold here in main shops are things like, beats by Dr, or shitty over priced branded generic ones
https://linustechtips.com/topic/553272-ear-phones/#findComment-7296575
i got these http://www.amazon.com/gp/product/B00C30FCUI?psc=1&redirect=true&ref_=od_aui_detailpages00 i think they're the same ? I'm not sure
Edit: never mind they're 100000% different, just hope they're good cause i just paid for them =[
https://linustechtips.com/topic/553272-ear-phones/#findComment-7296641
From what I can tell, they look like a good pair.
https://linustechtips.com/topic/553272-ear-phones/#findComment-7297348
