No it's not.
You need a CPU Cooler.
... No but seriously. Paste itself is not thaaat important (which one you take... If its a noctua paste, generic, Arctic cooling, etc). They differ in some degree.
What's important is the CPU Cooler.
If you use Boxed, you can use the best Paste you can find. the temperatures will be bad. And Bad -2°C is still bad.
before you "waste" 11 bucks on a thermalpaste, you might as well spend 11 bucks more for a better CPU Cooler.
Other than that... Which AMD CPU, which Clock speed, which Motherboard, how much Voltage, etc etc? So many more factors to consider ;)
https://linustechtips.com/topic/553168-thermal-paste-help/#findComment-7294654
4 minutes ago, Rev:) said:
Is generic insignia thermal compound enough to cool my cpu(8 core amd)?
Yeah it'll be fine, in the end of the day thermal paste is thermal paste unless you're using toothpaste you'll be fine
The most important part is applying the right amount of thermal compound, maybe watch a video before you do it to get a good idea.
https://linustechtips.com/topic/553168-thermal-paste-help/#findComment-7294658
yeah as long as it is not arctic silver 5 :P
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/553168-thermal-paste-help/#findComment-7294660
1 minute ago, Darkseth said:
No it's not.
I have a water cooler on it i was just wondering about the paste
https://linustechtips.com/topic/553168-thermal-paste-help/#findComment-7294662
wait your not suppose to use toothpaste?
https://linustechtips.com/topic/553168-thermal-paste-help/#findComment-7294674
I wish I could agree more. AS5 is a POS.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/553168-thermal-paste-help/#findComment-7294690
I found this article about it were they compared it to a Pentium 4 intel stock cooler thermal paste
https://linustechtips.com/topic/553168-thermal-paste-help/#findComment-7294696
you know, not that big of a deal unless you wanna run the risk of you know, have the metal melted to the heat spreader
https://linustechtips.com/topic/553168-thermal-paste-help/#findComment-7294703
I have 1st hand experience with it. I had already wasted money on it and wasted so much time repasting over and over because I thought I was doing something wrong, before I read a review comparing to other pastes. I wish I had read the review before I bought and wasted so much time. The cure time is ridiculously long and in the end it doesn't cool for shit. I don't get why it's so popular.
https://linustechtips.com/topic/553168-thermal-paste-help/#findComment-7294720
1 minute ago, Ronnie76 said:
you can use mayonnaise anything to separate the heat spreader to the cooler itself,  that is you know, able to conduct heat
Arctic Mayo 5
https://linustechtips.com/topic/553168-thermal-paste-help/#findComment-7294724
me *Hello patent office I need to patent my new product*
guy *what is it*
me *mayo in a syringe sold at $10 a tube*
https://linustechtips.com/topic/553168-thermal-paste-help/#findComment-7294740
You definitely sound like an expert on the matter.
/s
https://linustechtips.com/topic/553168-thermal-paste-help/#findComment-7294760
/s
Not sure what you're getting at. Are you insinuating AS5 is good?
https://linustechtips.com/topic/553168-thermal-paste-help/#findComment-7294773
I'm not insinuating anything.  I'm saying that it definitely isn't bad.  I too have had first hand experience with it...actually hundreds of first hand experiences over many years.  I've never had an issue with it or seen any major differences in temps compared to other TIM.  I agree that there are ones that perform better...and I have made a point to try out many different types.
https://linustechtips.com/topic/553168-thermal-paste-help/#findComment-7294855
15 hours ago, Ronnie76 said:
haha that's great :) I do notice AS5 gets mentioned a lot which seems to point people towards the mentioned brand as a way of astroturfing, Amazon New Anti Astroturfing Algorithm An Epic Fail video you may hear a few known brands:)
ay
Edited by oncloud9
did not want to double post
https://linustechtips.com/topic/553168-thermal-paste-help/#findComment-7298311
