Front vs. Rear Jacks
Solved by NinjaJc01,
1 minute ago, HunterSVK said:Heyo guys!
I got a question, is there a difference between pluging headphones in rear\front jack? Does the rear one have better quality, or it really doesn't matter?
Thank you in advace!
Quality is the same, unless you have some serious electrical interference. The main difference is that the rear jacks can often be repurposed for surround sound.
