WIFI issues
Go to solution Solved by littlepigboy5,
Just now, aneil1998 said:
Still no interent access :(
time for a new router then
So within the last hour, my wireless router has been giving me issues, which is that, i am not getting any internet access from it.
I am going form my ISP Modem to a network switch which then goes to my desktop, laptop and wireless router.
The laptop and desktop both have internet access from the network switch.
The wireless router make and model is:- Netis WF-2404
I tried turning it off and back on again(multiple times), tried different Ethernet cables to no avail, i tired connecting my laptop directly to the wireless router, still no internet access.
My suspicion is that the wireless router is dead. Can anyone confirm or deny that and offer some help please, Thank you.
Rig: Thermaltake Urban S71 | MSI Z77 G45-Gaming Intel Core i5 3570K (4.4Ghz @ 1.4v) CM Hyper 212 EVO | Kingston HyperX Fury 8GB | MSI GTX 660 | Kingston 120GB SSD | Seagate 3TB HDD | EVGA 850W B2
https://linustechtips.com/topic/552988-wifi-issues/
Are its lights on?
If so, open terminal, and run ipconfig, find the router's IP address and using that access its control page, and see if it displays any messages.
Primary Build: i7-4790 · 16GB Hynix DDR3-1600 · Sapphire Tri-X R9 390x · NZXT S340 · Win10 Pro · Seagate Barracuda 1TB T_T
Portable: 2015 Retina Macbook Pro 13" · i5-5257u · 512GB PCIe SSD · Intel Iris 6100 T_T
If my post helped you, please rate it!
https://linustechtips.com/topic/552988-wifi-issues/#findComment-7292614
there are some ways to test this.  First of all, learn what all of the light on your router mean to determine the issue.  You could also try acessing the router from you desktop or laptop by typing in the IP in ur address bar in a web browser.  If you can't access the router from being directly plugged into it, it's dead, but if you can access it, than it's strictly it's capability to actually passthrough/broadcast the signal.  Find the reset switch on the router/do it remotely via the client in the webbrowser and see if that works.
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
https://linustechtips.com/topic/552988-wifi-issues/#findComment-7292622
5 minutes ago, sushisharkjl said:
Are its lights on?
I can access the Routers UI and all lights are on. I'm going to reset the router next then :(
https://linustechtips.com/topic/552988-wifi-issues/#findComment-7292683
good luck, let me know how it goes
https://linustechtips.com/topic/552988-wifi-issues/#findComment-7292691
https://linustechtips.com/topic/552988-wifi-issues/#findComment-7292765
thanks for the help then.
https://linustechtips.com/topic/552988-wifi-issues/#findComment-7292782
Asus AC1900 or Google Onhub are both good choices.
https://linustechtips.com/topic/552988-wifi-issues/#findComment-7292812
DHCP loop?
Can you unplug all the LAN-side ethernet cables on the router? Just leave: switch to WAN (in) router.
It could be that you've ran 2 ends of the network back into the network, creating a DHCP loop. You can see this when the lights flicker very fast on the router. you're also not able to get to the router UI. Faulty homeplugs cause these to.
...or the router is broken...
I've never come across a Netis router before here in Europe. I can't judge the brand.
https://linustechtips.com/topic/552988-wifi-issues/#findComment-7293123
