Question about changing cpu
Go to solution Solved by Lotus,
If you haven't OC'd, do that first. It's a massive improvement on these chips. I went from 2.6 GHz to 3.9 GHz. It's free performance and not only that, but single-threaded performance as well. It's not that difficult, even though it is a bit more involved than a multiplier based overclock. Seriously, you really need to OC that CPU. You can likely hit 4.2 GHz+ with the right cooler. I was thermally limited by my Hyper 212 Evo. For comparisons sake, that 50% clock speed bump actually translated to around a 50% performance improvement.
The reason you can't overclock new processors via BCLK like you can LGA1366 is because LGA1366 is the last socket before they tied the PCIe bus to the baseclock. Raising BCLK in Sandy Bridge and newer will result in PCIe bus instability. Not true with Nehalem/Westmere, so you can increase BCLK. I ran mine at a BCLK of 195.
5 minutes ago, Evyatar said:
Do I need to change the drivers in any way?
No.
The CPU doesn't install any drivers on the PC, and if it does than it's all the auto-detect stuff.
You should be fine without changing drivers, it really only comes when changing the motherboard or GPU.
2017 Gaming PC
Excellent value machine, keeps me going.
CPU: Intel Core i5-6600K | GPU: Nvidia GeForce GTX 1080 8GB | RAM: 16GB DDR4 | Motherboard: MSI Z170A XPOWER GAMING TITANIUM
PSU: Casecom 600W PSU | Case: Corsair Graphite 230T | SSD: Samsung 850 EVO 250GB | HDD: 3TB WD Blue
Dell XPS 15 9560
Beautiful laptop, in a stunning form factor.
CPU: Intel Core i7-7700HQ | GPU: Intel HD Graphics 630/Nvidia GeForce GTX 1050 (not mobile, full GPU) | RAM: 16GB DDR4 | SSD: 512GB SK Hynix SSD
Display: 4K IPS 100% Adobe RGB Touch Panel | I/O: Two USB 3.0 with PowerShare, HDMI, 3.5mm Headphone Jack, SD Card Slot, and Thunderbolt 3 USB-C
Samsung Galaxy S8 64GB | Samsung Galaxy Tab S2 9.7 32GB
1 minute ago, R3DOPS said:
no. windows 10 8 and 7 will work fine.
Just now, AlphaGamer46 said:
No.
Ok
Thank you very much guys.
Oh and an other thing:
I've seen that the max memory on the exon's is like almost 10 times the max memory of the i7.
Can I upgrade the ram to the maximum of the exon's? (once I'll install it) Or am I limited by the motherboard some how?
Yoker.
Have you overclocked your current CPU yet? Also remember that those 6 core Xeons are great for multi-tasking, but unless you can reach a higher OC on them they aren't likely to be large improvements in gaming. That being said, my 3.9 GHz i7-920 is still a perfectly capable gaming CPU even with modern AAA titles.
1 minute ago, Evyatar said:
Ok
You are limited by the motherboard.
Depending on what mobo model you have, look at the spec page on the manufacturer's website for info about the max RAM you can install.
2017 Gaming PC
Dell XPS 15 9560
Actually this is why I'm upgrading, I need it more for the multitasking more then for gaming.
I don't like OCing since I don't really see the point, but maybe I'll OC the xeon since it's really low...
ps.
In some places I've heard that you cannot over clock xenon. is that true?
Yoker.
That's a bummer :( 6 slots and I'm maxed at 24gb.
Yoker.
Thanks for the help man, helped alot! :)
Yoker.
