Just now, NuclearPeace said:
Its normal. Pretty much every software I use calls my GPU a Radeon R9 380 series GPU instead of just the 380x. Crimson will be able to tell you if its a 380 or a 380x.
I'm in crimson and it says AMD Radeon R9 380 series. You're saying thats normal, correct?
https://linustechtips.com/topic/551857-r9-380x-issue/#findComment-7281391
GPUs are named in series - 380 and 380X are part of the 380 series, 7950 and 7970 are part of the 7900 series, 290 and 290X are the 290 series and etc.
Fury, Nano and Fury X are Fury series
https://linustechtips.com/topic/551857-r9-380x-issue/#findComment-7281420
