Medion Erazer PXE-E61 and BIOS problem
Solved by Thx And Bye,
Did you try to reset the cmos? (removing the CMOS battery)
You might need to open the casing for that.
I found a picture of the mainboard (check if its the right one) and marked you the CMOS battery: http://imgur.com/a/0o9CF
Featured Topics
RanchTheHay005 ·
1
2
alexfic ·
Posted in New Builds and Planning3 -
Pirateben ·
Posted in General Discussion1 -
frozensun ·
Posted in Storage Devices1 -
3
ammar666 ·
Posted in Troubleshooting4
