H100i help
Go to solution Solved by Frix,
Corsair link sucks It thinks ive got 3 fans plugged in and 2 led's on the cooler itself, I would uninstall it if I were you.
So came home today logged into my computer and get a message saying the corsair link 2 software experienced a problem and had to close. So I opened the software back up and it has h100i led thing at the top with nothing beside it. And the led isn't working inside the case. The cooler itself seems to be working, temps etc are all cool. Just the led isnt working
https://linustechtips.com/topic/55161-h100i-help/
 Asus M5A99X Evo  - AMD FX-8350 - 16GB Corsair Vengeance 1866Mhz - Corsair 120mm Quiet Edition Fans BenQ XL2411Z- EVGA GTX 980 Superclocked Fractal Design Define R4 - Corsair H100i - 2 TB 7200rpm HDD - Samsung 840 Evo 120GB - Corsair RM750w PSU - Logitech G502 Proteus Core - Corsair K70 RGB MX Red - Audio Technica M50x + Modmic 4.0 - LG 23EA63V x2
Spinthat Spinthat Spinthat Spinthat
https://linustechtips.com/topic/55161-h100i-help/#findComment-741501
Yeah I might, I just installed it when I received the h100i because I thought it was necessary.
So did I because I wanted to mess with the fan speeds and led lights, but in the end I threw my SP120's on there and I believe you cant actually change the speed of the aftermarket fan's so the only use for the program was the led, just uninstalled.
https://linustechtips.com/topic/55161-h100i-help/#findComment-741530
