I assume it is soft. I would not recommend heating up the tubing because you could damage it and it will not really do that much for you.
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/551287-tubing-question/#findComment-7275588
35 minutes ago, Slickwicked said:
Someone suggested to heat up the ends of the tubing before putting it on the fitting, claiming it made a better seal, I'm using fittings and tubing of the same size. Is this true?
Thanks
For soft tubing it can help it fit of fittings especially if it's thick walled tubing, by dripping the end in hot water for a little bit.
https://linustechtips.com/topic/551287-tubing-question/#findComment-7275614
I wouldn't bother. You could end up damaging the tubing with the heat. I didn't do that and so far no leaks. I would recommend tightening the fittings every few months since the tubes may warp after being heated and cooled repeatedly over long periods of time.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
https://linustechtips.com/topic/551287-tubing-question/#findComment-7276119
3 hours ago, Slickwicked said:
Oh man, one no, one yes,  it's 3/8 x 5/8 btw,
Dipping it on hot water will not damage the tube but if you can easily get it onto the fittings then you don't need to do that.
https://linustechtips.com/topic/551287-tubing-question/#findComment-7276455
Heating up the tubing using hot water isn't going to be a huge deal -- just make sure it's just hot and not near boiling. If you have a coffee maker, run it without grounds and the temperature of that water will be just right after you let it sit for a little bit. But before going that far, put some distilled water on the fitting first, as that could give a little lubrication to help get the tubing onto it. If that's not helping much, then go for the hot water.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
https://linustechtips.com/topic/551287-tubing-question/#findComment-7278614
Thanks
Unless you melt the tube onto the fitting, so does it not make a difference at all.
Only reason to heat the tube, is to getting it proper on (if you have that problem), but hot water will do that just fine.
I speak my mind, sorry if thats a problem.
https://linustechtips.com/topic/551287-tubing-question/#findComment-7279133
