HBI have a problem i building my first PC
-ASUS Maximus VIII Hero (LGA 1151, Intel Z170, ATX)
-Thermaltake Overseer RX-I (VN700M1W2N) Window (Big Tower, Schwarz)
-MSI GTX 970 Gaming 4G (GM204, 4GB)
-Samsung 850 EVO Basic (500GB, 2.5")
-Intel Core i7 6700K_BOX (LGA 1151, 4GHz, Unlocked)
-Corsair Vengeance LPX (2x, 8GB, DDR4-2133 MHz, DIMM 288)
-Noctua NH-D15
-Microsoft Windows 10 Home OEM, DE, 64-bit)
-Seagate Desktop HDD - 3.5" SATA 6Gb/s - 1Tb
-ASUS DRW-24F1MT (Schwarz, Silber)
-be quiet! Pure Power CM L8 (630W)
I built everything together but it wouldnt Boot and it showed Error53 (Memory Speed and compatibilty). I lokked and my ram isnt listed in the supported ram list for the motherboard. Should i try to put the ram in the other ram slots or xo i have to buy other ram thats supported? (Like tge same with 3000MHz)(and i cant get into tge BIOS)
It worked i changed the hdmi with VGA and the ram in different slots
https://linustechtips.com/topic/551134-problem-with-ram-memorysolved/
-Noctua NH-D15
can you get to the bios? try just one stick a time
10 minutes ago, Jacktastic-Mofo said:
Try turning on XMP Profile 1 in the BIOS.
I believe 2133 is the default speed for most 170 boards, and XMP shouldnt be needed unless you are trying to clock higher, which is not the case in this situation.
What DIMM slots do you have the RAM installed into?  You manual should tell the optimal slots for two sticks.  For example, for my board, it suggested installing in DIMM #2 and #4.
Also, triple check that the RAM has been pushed down hard enough - they actually require quite a bit of force.  It is possible that the RAM just doesnt work with the board, although unlikely given the RAM you selected is pretty common / generally compatible, so best to try these other solutions first.
|[ i7 6700k ][ MSI z170a XPower Gaming Titanium MB ][ 16gig G.Skill Trident Z 3000mhz ][ Gigabyte Xtreme GTX 980ti ][ Samsung Evo & Intel SSDs ][ Corsair 540 air ][ XFX Pro 750w Platinum ][ 24" Asus 144hz ]|
