Does Gsync and higher resolution cut pc performance?
I just got an Asus pg279q and its beautiful! However, I've had issues with it that don't really make any sense to me.
1. Games take MUCH longer to load in. I play League of Legends and with my old 1080p monitor plugged in my games load nearly instantly, but now it takes about 60 seconds for the loading screen to even come up.
2. Games crash when I alt tab even in windowed mode. This issue doesn't happen often, but when it does its also when I have curse voice up. It never happens on my old monitors.
3. Huge stuttering problems when I have my other two monitors hooked up (3 monitors total). When I'm playing a game and have my music open on youtube I get issues with stuttering. My FPS in league of legends says its about 130~ when I have all of this going but I keep seeing "Jumps" every few seconds.
I have a fairly high end gaming pc so I don't see why all these problems are happening. Is it a known issue with Gsync or something?
CPU: Ryzen 5950X Ram: Corsair Vengeance 32GB DDR4 3600 CL14 | Graphics: GIGABYTE GAMING OC RTX 3090 |  Mobo: GIGABYTE B550 AORUS MASTER | Storage: SEAGATE FIRECUDA 520 2TB PSU: Be Quiet! Dark Power Pro 12 - 1500W | Monitor: Acer Predator XB271HU & LG C1
Higher resolution obviously requires more GPU power to render more pixels. G-sync however should not have a noticeable performance hit.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
I wouldn't expect a 980Ti to have any problems running a MOBA at 2k though
check the driver, maybe do a fresh install and ensure all your power settings are "max performance"
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
YouTube videos (or other video playback) will cause issues if they are running visibly at the same time as a game. The other two things don't sound like they have anything to do with the monitor. If you did anything else around the same time as upgrading you monitor, try undoing that.
