Hello everyone, so this morning i woke up to my computer saying no boot option available, right away assuming that my hard drive failed. Note that i do have two hard drives in my system and i proceeded to uplug the second drive and start up the computer to test the system, what i found is that the system booted up perfectly fine. When i shut down the system again and plug back in the second drive then start up again it will load up to the loading screen but then remain there at the loading screen. When ive gone into the UEFI to check the boot order my drive with the OS does not show up yet it will start up if it is the only drive attached to the system. What i am suspecting is that there may be an issue with the motherboard and either it may need an update or something is wrong by sata ports but this is just my theory.
System:
Asrock Z97 Killer Fatality
I7 4790
R9 270X
HDD's are a WD 1TB blue and a Seagate Barracuda 1TB
Gskill Sniper 16GB 2400Mhz
https://linustechtips.com/topic/550969-system-bootup/
