For the longest time i have always used a wired headset. It first started out with the razer megalodon a 7.1 surround sound headset. Most of the time it was in default 2.0 as it said but, When i put music on 9/10 times i put it in 7.1, I had the headset tuned to my music preference so, 7.1 always sounded amazing, after about 2 and half years it started to die with razer discontinuing it so, I got the Logitech 930 wireless head set after seeing my close friend use it for over 2 years. I have never had more problems with a headset then this one, When i first got it i had to get drivers that i think were from 2013 and, It still doesn't always work, Other times the mic starts to cut in and out but, i do not know if that's the headset or skype also, When i put the mic up its suppose to mute which sometimes does it and, Sometimes doesn't. so right now i am looking to get a new wireless headset before this completely dies. Just to note i got this headset in December of last year so its only a few months old. My question is does anyone have a recommendation for a wireless headset under about 100 US dollars.
https://linustechtips.com/topic/550890-quality-wireless-headset/
Yeah you need to put what 300$ down or so to get some decent wireless headphones like these http://www.amazon.com/Sennheiser-RS-185-Wireless-Headphone/dp/B00TOT9G1W/ref=sr_1_1?ie=UTF8&qid=1455879726&sr=8-1&keywords=rs+185
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/550890-quality-wireless-headset/#findComment-7271406
7 minutes ago, gunzsmithy said:
problem with the Sennheiser is that i am not a audiophile so they would be a waste on me.
Trust me you will notice the difference between the "gaming" headsets and the sennheiser headphones. the lower models are also pretty good
http://www.amazon.com/Sennheiser-RS-160-Wireless-Headphones/dp/B002SOU2Y0/ref=sr_1_1?ie=UTF8&qid=1455880334&sr=8-1&keywords=RS+160
http://www.amazon.com/Sennheiser-RS-170-Discontinued-Manufacturer/dp/B002TLT10I/ref=sr_1_1?ie=UTF8&qid=1455880350&sr=8-1&keywords=RS+170
Once you try real headphones you will never go back to the "gaming" headsets
https://linustechtips.com/topic/550890-quality-wireless-headset/#findComment-7271428
Just now, gunzsmithy said:
problem is i am a gamer, I use the mic for skype chat and, other com's
mod mic for better quality.
Cheap china mic if you want the same quality as the "gaming" headsets has...
https://linustechtips.com/topic/550890-quality-wireless-headset/#findComment-7271439
I have some cheap mics from china that I got for 0.8$ each and they sound better than the ones razer and steelseries put on their mid range products.
https://linustechtips.com/topic/550890-quality-wireless-headset/#findComment-7271451
that is always a option, while i am hardware person i am not the best with mods, not as much experience.
I use lavalier mic that I clip onto my shirt
https://linustechtips.com/topic/550890-quality-wireless-headset/#findComment-7271459
I have the Astro A50 Gen2.  No complaints here.
Expensive?  Yes.
Better sounding than my Seinheissers?  No.
Best wireless headset w/ a mic I could find that I can use for my PS4/XBOX1?  Probably.
A50s are very bass heavy on the media mode, but on the pro mode it's not bad whatsoever and I find myself using them more than my other headphones/headsets.
Very comfortable right out of the box.
If you do save up and get A50s for use with the PC make sure you have a soundcard that supports DDL or your onboard audio has DDL. (DDL = Dolby Digital Live)
It was either the newer Astro A50 or the Siberia 800.  I went with the A50s and have no regrets.
Good luck!
https://linustechtips.com/topic/550890-quality-wireless-headset/#findComment-7271544
14 minutes ago, gunzsmithy said:
the problem i have is that i want both good mic quality and, amazing sound for cheap which is not going to happen
maybe look used?
https://linustechtips.com/topic/550890-quality-wireless-headset/#findComment-7271547
Just now, DotComBubblegum said:
ewww imagine all that sweat and filth on it from someone else... grosss
Uuhhmm clean them? Change the pads?
https://linustechtips.com/topic/550890-quality-wireless-headset/#findComment-7271627
Steelseries H wireless or by the new name steelseries siberia 800,though dunno how much it is in US, most probably 200+, more likely $300.
CPU: AMD Ryzen 9 5900X 12; GPU: GeForce RTX 3080 Gigabyte Vision OC V2 10GB; PSU: EVGA 750W 80+ Gold Certified; RAM: 4x32GB (w/RGB xd); SSD: 1xM.2 Samsung 980 Pro 1TB, 1xM.2 Samsung 970 Pro 1TB, 1xWD 6TB HDD; OS: 10; Monitor: 1xAorus IPS 27" (2560x1400) 1xBenq IPS 32" 4kKeyboard: Corsair K95; Mouse: Logitech G Pro X Superlight w/ Steelseries QcK mousepad.
Laptop - HP Omen 15" w/5800U, GPU 3070, 1TB M.2 WD Black, 2TB M.2 Samsung 980 Pro, 64GB RAM.
https://linustechtips.com/topic/550890-quality-wireless-headset/#findComment-7273344
