Why is a 270X at 81°C??
nevermind . But don't worry about it, you're far from the max temperature. If you're worried, take the cooler off, replace the thermal paste, and put it back on.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/550080-max-temps/#findComment-7262729
Its at 81 degrees because I moved my radiator to the front of my case for my CPU because it runs exceptionally hot at stock. With my radiator in the top it is like max 66 degrees
Breaking things 1 day at a time
https://linustechtips.com/topic/550080-max-temps/#findComment-7262739
44 minutes ago, TubsAlwaysWIns said:
Just curious as to what you guys thing the maximum temperature is for a MSI R9 270X HAWK. I max at about 81 degrees (with my radiator in the front of the case). I dont mind turning up fans if needed because my fans already run pretty loud
A max/dangerous temperature for a GPU would be anything above 100°C IMO.
https://linustechtips.com/topic/550080-max-temps/#findComment-7262861
A radiator should not cause that much heat. Make sure your case has good airflow to the GPU. Trust me, your CPU will not make your GPU 15°C hotter.
The Laptop:
https://linustechtips.com/topic/550080-max-temps/#findComment-7265027
Well with my radiator in the top of my case it maxes out at 66 degrees and in the front it is at 81 degrees. usually 75 though. You also have to keep in mind im riunning a AMD processor overclocked quite a bit
https://linustechtips.com/topic/550080-max-temps/#findComment-7266024
Again, make sure that even with the rad in front, you have good airflow to the parts. A recent JayzTwoCents video is where I got my information, and that was on an overclocked i7. It shouldn't change temps much if at all.
The Laptop:
https://linustechtips.com/topic/550080-max-temps/#findComment-7266048
Part of it was i was running Intel Burn Test (to get in temps for my OC) and the Heaven Benchmark just to get worst-case scenario temperatures
https://linustechtips.com/topic/550080-max-temps/#findComment-7266062
That's quite hot for a Southern Islands card, if you don't mind the noise set a custom fan curve to keep the temp down.
        Pixelbook Go i5 Pixel 4 XL
https://linustechtips.com/topic/550080-max-temps/#findComment-7266063
Just now, TubsAlwaysWIns said:
I have one on there, and i can raise it even more
Your probably going to have to do that.
https://linustechtips.com/topic/550080-max-temps/#findComment-7266081
He used Aida 64 and Heaven at the same time to get his temps.
The Laptop:
https://linustechtips.com/topic/550080-max-temps/#findComment-7266093
1 minute ago, TubsAlwaysWIns said:
I just did. It goes to about 70% RPM at 45 degrees up to 80% RPM at 80 degrees
Is it to loud to push that to 100%, and preferably at 75°C.
https://linustechtips.com/topic/550080-max-temps/#findComment-7266101
Who is 'He'
JayzTwoCents, who I referenced.
The Laptop:
https://linustechtips.com/topic/550080-max-temps/#findComment-7266118
yeah. 70% is just before it gets to a noticeable difference
Ahh, why don't you move the CPU radiator back to where it was and see if it makes a difference?
https://linustechtips.com/topic/550080-max-temps/#findComment-7266136
because my cpu gets SUPER hot when its up there. Like theres a 15-20 degree dfference from the top of the case and in the front
https://linustechtips.com/topic/550080-max-temps/#findComment-7266148
I got the Asus one. Max. peak of 79 Degrees while having the fans never above 60%. You should be fine, as long as i dont runs at that temperature 24/7.
Budget Rig "Curable":     | FX 6300 @4.5Ghz | Asus R9 270x | Asus Crosshair IV Extreme | 16GB HyperX Beast | 120GB PNY SSD
Tablet "Buddy":                 Trekstor Wintron 10.1|
https://linustechtips.com/topic/550080-max-temps/#findComment-7266160
You could try undervolting your card and see if it remains stable.
https://linustechtips.com/topic/550080-max-temps/#findComment-7266165
I will go in the 80 degree range at 4.3 up in the top and about 75 degrees at 4.5 in the front
https://linustechtips.com/topic/550080-max-temps/#findComment-7266166
Whats undervaluing? like down-clocking?
Yeah autocorrect turned it to undervaluing instead of undervolting, it's basically seeing if your card can run at a lower voltage with the same clock speed.
https://linustechtips.com/topic/550080-max-temps/#findComment-7266196
