Hey Im Building A Custom Pc but i don't know what motherboard to choose,
Specifications
Lga 775
ddr2 x4
pci
graphics card
and x2 sata
If You have any suggestions please reply :)
(i will be able to find a psu which fits the motherboard when i find a motherboard)
I'm A Cactus !
https://linustechtips.com/topic/550054-pc-part-help/
Specifications
Lga 775
ddr2 x4
pci
graphics card
and x2 sata
if you can find an asus, id say do that
just not sure if this range works
https://linustechtips.com/topic/550054-pc-part-help/#findComment-7262435
Do you already have the other old parts lying around or something?
https://linustechtips.com/topic/550054-pc-part-help/#findComment-7263177
