Okay so! I'm working on a new build and I'm starting to get parts in and I'm looking forward to build it. I purchased the Corsair Hydro Series H110i GT as a water cooler, I know this is the aircooling section.
The question that I have is which fans would be good to put on the radiator? I'm looking for static pressure fans, I'm going to be running it in a push/pull configuration so I'm looking for four fans.
The fans have to be high performance, can't be an ugly color scheme! No noctua ugly color pls, thanks! Let the recommendations begin!
Oh yeah and I'm also looking for Air Flow fans to put as an exhaust fan in the case and two front Air Flow fans as well.
Please make sure all of the fans are the same brand/company and make sure they have Air Flow/Static Pressure series of the fan, thanks!
https://linustechtips.com/topic/549957-case-fans/
Corsair seem to be a renowned case fan recommendation. SP120 or SP140s for static pressure on radiators and AF120 or AF140 for air flow. There are a good few other brands. EK do those vardar (i think thats what you call it) fans that are specific for radiators. Also, get PWM fans for radiators so they will ramp up or down depending on CPU temps
EVE (My Gaming Build)
Motherboard: Asus Maximus VII Ranger - CPU: Intel i5 4690k @ Stock Speeds - Cooling: Phanteks TC-12DX - PSU: Corsair RM750 - GPU: MSI GTX 1070 - Storage: 1x 120gb Samsung 830 Evo SSD (OS Drive) | 1x 120gb Hyperx 3k SSD (Audio Editing) | 1x 480gb Sandisk Ultra II SSD (Games) | 1x 1TB Hard Drive (Mass Storage) - Case: NZXT Phantom 530 - Misc: NZXT Hue RGB LED and controller
https://linustechtips.com/topic/549957-case-fans/#findComment-7261265
Wait and see how the fans that come with it work first? They will most likely be fine.
If the performance still isn't what you're after, go for more is what I'd do.
Not sure really what exact fans for anything, but that's what I can say.
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
https://linustechtips.com/topic/549957-case-fans/#findComment-7261276
