You dont need that much ram, if you have a ****K (overclockable) cpu u will need a chipset with x or z (like z170), compared to your cpu your gpu is pretty weak.
I'd just post my budget, my location and what ill be using the pc for. and somone will surely make you a build
https://linustechtips.com/topic/549931-first-build/#findComment-7261062
Oh my god :o. That powerful CPU combined with that extremely weak GPU... 32GB of RAM and B150 chipset motherboard with an unlocked CPU. Normal build should look like this: http://pcpartpicker.com/user/Tautedorus/saved/VW3LrH
Just now, Tcain1993 said:
my budget is $120 and i will be using my pc for gaming and entertainment like itunes
If you are on a tight budget: http://pcpartpicker.com/user/Tautedorus/saved/HzfXsY
https://linustechtips.com/topic/549931-first-build/#findComment-7261121
