5 hours ago, LoGiCalDrm said:
Depends if mobo supports OC with non-K CPUs. BIOS is still more recommended though.
That's probably what I should stick too... and is that the same reason, why the all the options in the 'Advanced Tuning' tab grayed out?
Nothing to see here ;)
I'm not sure. Can you access those options in BIOS? If yes, then, since its Intel software, they don't want to support deeper OC on other than K-line CPUs.
Had to reintall XTU to see how it looks. I've used it to benchmark back when I got this CPU.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Thanks man!
