Hi, My budget for my first build is $400, I do plan on putting a lot more into it in the future though. Id like to be able to play games like BF3 at a decent 60fps normal-high settings 1080p but I dont know if my build would be able to do that as I am fairly new at this. If I have to I will spend more but I also have to keep in mind that I still need to buy a monitor, keyboard, mouse, speakers, and operating system.
Im sure this build can be improved a lot so if  any improvements can be made let me know!
My Build so far: http://pcpartpicker.com/p/1BZcb
If I could go cheaper and still play on normal-high settings id like to know. I could use the money to upgrade it later on.
https://linustechtips.com/topic/54955-400-first-build-need-help/
If you're going to be using an APU you need fast RAM. It will benefit the APU a lot and give you more frames. I would go with 2133Mhz of your choice.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/54955-400-first-build-need-help/#findComment-738261
Save up and plan later. You don't have enough considering you still need peripherals and such.
https://linustechtips.com/topic/54955-400-first-build-need-help/#findComment-738268
This. Shoot for $600+ preferably to start with.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/54955-400-first-build-need-help/#findComment-738282
