Roccat Kone Pure Optical (KPO) vs Kone Pure Military (KPM)
Solved by Big_Chief,
KPO uses older 3090 sensor, resulting in some loss of accuracy and tracking speed as the DPI increases. KPM uses newer 3310 sensor, pretty much the successor to the 3090, and doesn't lose much, if any, accuracy and tracking speed over the whole 5000 DPI range. If you're using 400 DPI for CSGO, both perform well on that setting. If you're going to use a higher DPI at any point, maybe for 1440p or 4K eventually, I'd get the KPM for it's more customisable 50 DPI increments.
