Hey,
Looking for some help upgrading my gpu. Currently 280X but thats irrelevant. Im looking at buying a 1440 144hz monitor (predator or swift not too sure yet). What I want to know is if a 980 will be able to run most AAA titles at max settings at 144fps or whether i will have to go with a 980ti or titan. Anyone have any advice?
Thanks guys
https://linustechtips.com/topic/549392-help-chosing-gpu/
1 minute ago, RyanVDL said:
Hey,
Thanks guys
yes it would but! you could save money by geting a 970
CPU: Intel Core i9 9900K | Ram: 32GB Corsair LPX 3200 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
https://linustechtips.com/topic/549392-help-chosing-gpu/#findComment-7254718
You will probably be fine with THIS generation of AAA titles (AA off), but you won't have a lot of head room for the future.
I would see if you can squeeze a 980Ti into your budget. It offers much more bang for the buck. There is also a massdrop for a 980Ti for $619 with a $30 MIR
Also don't get a titan.
CPU: Intel Core i7 8700k CPU Cooler: Corsair Hydro Series H100i Mobo:  Memory: G.Skill Ripjaws X 32GB 2133 Storage #1: 1TB 850 EVO SSD Storage #2: Western Digital Black 2TB Storage #3: Western Digital Green 4TB GPU: Gigabyte 980 Ti G1 Case: Mastercase5 PSU: EVGA 750 W G2 80+Gold Keyboard: Corsair K70 RGB Cherry MX Brown Mouse: Razer Deathadder Elite Monitor: LG 34UM94 Headset: Bose
Phone: Samsung Galaxy S9
https://linustechtips.com/topic/549392-help-chosing-gpu/#findComment-7254730
1440p 144hz ? I doubt it.
CPU: Intel i5-4590 | Motherboard: Asus H97M-E | GPU: Sapphire Nitro R9 390 | RAM: 2x4Gb Kingston HyperX Fury Black | SSD: Sandisk Plus 240Gb HDD: Seagate 250Gb  | PSU: Seasonic G650 80+ Gold | Case: NZXT S340
I am who I am.
https://linustechtips.com/topic/549392-help-chosing-gpu/#findComment-7254735
Most people on line say 980ti is best for consistent frame rates and future title. Its also easily SLIable in the future
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
https://linustechtips.com/topic/549392-help-chosing-gpu/#findComment-7254738
a 970 would have a lot of trouble doing 1440 at a high frame rate. I was running a 970 with 3440x1440 and in GTAV only had about 30fps
https://linustechtips.com/topic/549392-help-chosing-gpu/#findComment-7254739
trust me i have run a system with a 970 and a 144hx 1440p monitor and got ok result but on high but not ultra
https://linustechtips.com/topic/549392-help-chosing-gpu/#findComment-7254740
Read.
I am who I am.
https://linustechtips.com/topic/549392-help-chosing-gpu/#findComment-7254746
Yeah I was also looking at getting some head room for the future. Im also running 2 1080p Monitors, running non gaming things like facebook and streams and what not. Will that effect the performance from the Ti at all?
https://linustechtips.com/topic/549392-help-chosing-gpu/#findComment-7254748
I *think* those types of apps don't really draw much gpu performance. I use a PS2 emulator, and even that is not enough to make my 980Ti work over 40% (silent fan mode under 40%)
https://linustechtips.com/topic/549392-help-chosing-gpu/#findComment-7254766
I recommend you wait till the new generation of GPUs come out, and then get the most powerful card you can buy. I'm sure you can make do with your 280x until then ;)
ZamoRIG 2.0:
Processor: AMD Ryzen 7 1700 @ 3.9GHz
Cooling: DeepCool Captain 240 RGB + 2x Corsair ML120 fans
Graphics Card: Gigabyte GTX 1070 G1 Gaming x2
Motherboard: Asrock X370 Gaming K4
RAM: 2x8GB DDR4 G Skill Ripjaws V Grey @ 2800MHz
SSDs: 2xPatriot Ignite M.2 240GB
HDD: WD Black 1TB + WD Green 2TB
 PSU: Corsair RM750
Case: Corsair Carbide 400C
ZamoRIG “Portable”:
Processor: AMD Ryzen 5 1600 @ 4GHz
Cooling: Corsair H80i
Motherboard: Gigabyte AB350N Gaming WiFi
RAM: 1x16GB DDR4 Corsair Vengance  @ 2400MHz
SSD: Patriot Ignite M.2 240GB
HDD: 2TB 2.5” Seagate HDD
PSU: Corsair TX650M
Case: Siverstone SG13
https://linustechtips.com/topic/549392-help-chosing-gpu/#findComment-7256134
