HI i am fixing a iphone 4s for a friend and i am having trouble with it trying to even charge to boot! any advice i am using msi super charger to help speed it up
CPU: Intel Core i9 9900K | Ram: 32GB Corsair LPX 3200 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
https://linustechtips.com/topic/549390-any-help/
I think the first step is to see if it is actually dead. (Do you see the red battery symbol?)
If you don't the issue may be different, and my recommendation is to try to hold the power and home button for ~15 seconds, and see if anything happens.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/549390-any-help/#findComment-7254710
the battery is on the screen but not booting
https://linustechtips.com/topic/549390-any-help/#findComment-7254722
How long has it been charging, I would wait at least 30 minutes of charging before seeing if there is a different issue, assuming the charger works.
Is there a different issue? or is this preventing you from fixing a different issue.
https://linustechtips.com/topic/549390-any-help/#findComment-7254751
well my friend said the battery life sucks and its been chargeing for 10mins i am used to my 6s plus booting fast
https://linustechtips.com/topic/549390-any-help/#findComment-7254756
Then I would wait.
There's no real way to fix crappy battery life, other than to replace the battery, which probably won't fix it.
https://linustechtips.com/topic/549390-any-help/#findComment-7254768
