Probably a simple fix, but does anyone know what a int& parameter is requiring? I thought it would be a memory address but Visual Studio is saying otherwise. Thanks!
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/549169-simple-c-problem/
It's a reference , not a pointer.
Just pass the value normally.
https://linustechtips.com/topic/549169-simple-c-problem/#findComment-7252369
It's asking a reference to an integer variable, it's not a pointer.
For example:
void changeMyVar(int& var)
  var = 100;
int main()
  int myVar = 0;
  changeMyVar(myVar);
  std::cout << myVar;
  return 0;
will change the value of the main's myVar variable to 100.
https://linustechtips.com/topic/549169-simple-c-problem/#findComment-7252398
I see, thanks! One more question, I'm trying to implement sorting algorithms that work with floats, integers, and strings. And since I have to swap positions of items during the Partition stage of Quicksort, what type should I be using for the temporary variable to store items during swap?
https://linustechtips.com/topic/549169-simple-c-problem/#findComment-7252479
