Hi guys need some opinion if I should go with 2 rads fan or 3 rads fan on this case? Thank you!
PS: If I go 3 fans I'd have to remove the first media bay and that's okay but my main concern is that its a blocked? Because its going into the bay slot.
And I'm going with the Thermaltake Water 3.0 Riing RGB 360mm AIO Liquid CPU Cooler or 2 rings just so you let you know hehe. It has RGB rings on the fans.
Suggestions pls! Thank you!
https://linustechtips.com/topic/548929-help-decide-pls/
7 minutes ago, RappyPop said:
Hey man, do u know if I could like cut the first bay? so its open do get what I mean?
You mean remove the 5.25" bays? I'm not sure if you can do that, but I do know that the 360 rad can mount with it still in place.
"Do as I say, not as I do."
-Because you actually care if it makes sense.
https://linustechtips.com/topic/548929-help-decide-pls/#findComment-7250134
Yeah I believe so to.. I jst wanted clearer view of the 3rd fan so I wanted to cut the 5.25" top bay..
https://linustechtips.com/topic/548929-help-decide-pls/#findComment-7250284
I'm sure someone here has one and can say for certain. I've built someone else's system in one before, but I didn't really pay attention to that.
The documentation on Corsair's website says the 3.5" and 2.5" bays are removable, a shame they don't say definitively whether the 5.25" bays are as well...
https://linustechtips.com/topic/548929-help-decide-pls/#findComment-7250334
