Code Name: Chameleon (first build)
So this was my first build and I plan on using it for video editing, animations, and gaming.
CPU: Intel Core i7 6700k
Cooler: NZXT Kraken X61
Motherboard: ASUS Z170 Deluxe
Memory: Corsair Vengeance LPX 32GB (4 x 8GB)
Storage: 2x OCZ Trion 150 240GB
              Western Digital Black 2TB
Graphics: Galax GTX 980 Ti HOF
Case: CoolerMaster MasterCase Pro 5
Power supply: EVGA Supernova 1000W P2
Fans: Fractal Design GP-140
Fan Controller: NZXT Grid+ V2
Lighting: NZXT Hue+
USB Controller: NZXT IU01
And here is the picture of the build process:
(The red and black cables will be replaced with all white cables, I'm just waiting for them to come back in stock)
This is proof that you can put a 280mm radiator in the Mastercase Pro 5.
In case you can't tell, I am not happy with the red cables.
I spent well over an hour on cable management and trying to get the side panel on.
56c262cb12879_Screenshot_2016-02-13-10-5
And now I must wait for the white cables.
So, how did I do for my first build?
https://linustechtips.com/topic/548668-code-name-chameleon-first-build/
5 minutes ago, Marziman said:
Nice build overall, I like the red cables though.  It adds a nice accent.
I have to say I agree with this, but single sleeved red cables would be better. Or maybe white and red single sleeved?
Overall though it looks great! good work man!
Intel i7-5820k OC'ed to 4.2GHz @1.225 V; w/ Corsair H110i GTX2x Asus Strix 980ti's; Asus Rampage V Extreme; 16GB (2x8GB) Crucial Ballistics GDDR4 RAM; EVGA 1000P2 psu
http://www.3dmark.com/3dm/8608142 boost clock of 1493MHz
https://pcpartpicker.com/user/jjar35/saved/#view=ghCWGX + 43" 4k Vizio M-Series TV
10 minutes ago, theninja35 said:
Nice color scheme and cable management. Any reason for the naming?
The reason for the naming was the all black interior doesn't reflect much light while the white reflects all light. So the name came from the idea that I could change the entire color scheme of the PC just by adjusting the color of the Hue+. That is also when I can't stand the red cables. Right now I have the color set to a deep purple and the red cables stick out.
