4790k Temp Issues
Solved by BlueClown,
10 hours ago, LoGiCalDrm said:Eh, what? Does it intake outside of case or inside? If it intakes fresh air from outside the case, having GPU close doesn't matter at all.
I dont know what i was thinking, totally forgot it was intake... my bad.
Still manage to get Turbo Enable with 39-40c Idle and 64 to 70 (with a 60% load) was late already so i wasnt able to test with more cpu heavy games or stress tests (will do it today). Im guessing that the last culprit would be my room temp, I live in a hot country and with no air conditioner its seems like "ok" temps (still doesnt explain how my friend has lower temps thou, maybe really its the gpu he has a gtx 970).
Thanks for all the reply anyways.
