GPU Fan Questions
Go to solution Solved by Godlygamer23,
Just now, Made In Canada said:
I do not have anything like that in any of my boxes.
The connectors say VGA on it.
Long story short, when i try to plug in my GPU fan header (or at least that is what i think it is) my whole computer won't start after that. My question is 1: Do i need to plug it in or will the molex plugins power it? 2: If i must plug it in, where do i plug it into? My Motherboard is a asus z97-a, GPU is a EVGA GTX 970 ACX 2.0, and PSU is a EVGA nexb1 750w 80+ bronze semi modular.
Can anyone help?
The Canadian Version Of Everything
-Made In Canada
https://linustechtips.com/topic/547790-gpu-fan-questions/
Can anyone help?
you plug a gpu fan INTO THE GPU
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238041
GPU fans plug into a fan header on the GPU's PCB. A GPU is powered by a dedicated cable. I dont think a molex would provide enough power. pics would help.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238052
Either you have some special rare GPU that has a fan header for its fans or you are doing something horribly horribly wrong!
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238080
11 minutes ago, Nacho Marco Segui said:
GPU fan header...
I have the exact same (plusthe SC) GPU... Never heard of it...
The fan cable plugs in the pcb of the gpu, what molex cable are you talking about? Post a pic
The "fan header" thing i am talking about is a 4 hole cable that has 1 side with a square thing on one side and a line going down the 3rd (or 2nd) hole. i am generally new to this so sorry if i don't understand what you fully mean (such as PCB). Also, the cables with the molex seemed to have come with the GPU (its called a PERIF, i have 2 of them, one with 3 molex connectors and another with 2 and the fan header thing)
PERIF
-Made In Canada
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238109
The "fan header" thing i am talking about is a 4 hole cable that has 1 side with a square thing on one side and a line going down the 3rd (or 2nd) hole. i am generally new to this so sorry if i don't understand what you fully mean (such as PCB). Also, the cables with the molex seemed to have come with the GPU (its called a PCEIF, i have 2 of them, one with 3 molex connectors and another with 2 and the fan header thing)
were gonna need some pictures
also, do you mean cpu?
gpu is graphics card
cpu is processor
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238115
when i opened it it said the fans won't start till X amount of load or something, and how it has to be changed manually.
-Made In Canada
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238117
A picture is worth a thousand words. especially when troubleshooting computer issues.
The GPU is powered by these which come from the PSU 7GRoNic.jpg.
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238121
Mine says PERIF and are almost identical to these but with 2 6's and no optional 8.
-Made In Canada
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238133
cpu is processor
GPU is the processor found on the graphics card PCB, essentially the "CPU" of that component. CPU is the processor found on the motherboard.
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238138
in that case
WHAT THE HELL ARE YOU DOING
GRAPHICS CARDS COME PRE ASSEMBLED
Im talking about how it is all assembled on its own, i plug it to PCIe, i get come weird connectors with the GPU that go from 6 holes to molex adapter, i assume thats what i do.
-Made In Canada
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238143
Those are just adapters if required. If you have the cables already with the power supply, use those. Not the molex connectors.
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238150
oh god
no
what you do
is not use the molex for anything
plug the 6 and/or 8 pin directly into it from your psu
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238153
4 minutes ago, Josephdalepi said:
in that case
15 minutes ago, Ronnie76 said:
GPU fan header...
If you all can wait a minute, i will try to get some pictures.
-Made In Canada
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238155
Just now, Josephdalepi said:
i know
i was hoping he was confusing them, because this doesnt make any sense
I think I've figured it out. He's talking about the adapter that comes with the graphics card that goes from two Molex to PCIe 6/8 pin.
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238157
i figured it out at the exact same moment
we posted almost simultaneously
thank god we figured this out...
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238164
other way around, from PCIe 6/8pin to molex, other than that, you are right.
-Made In Canada
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238166
Well, it comes from the power supply to the graphics card. That's the order in my mind. Guess I'm thinking about the way the current is going to travel.
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238179
In that case, you are extremely correct.
-Made In Canada
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238199
43 minutes ago, Ronnie76 said:
GPU fan header...
Here Is The Picture, sorry for the delay. Remember that it goes from GPU, two 6 PCIe to 2 molex, per 6, so a total of 4 molex. So am i doing this right? PS the fan header thing with the 4 holes is what i am holding with my thumb.
ANY ADVISE HELPS.
My questions were 1: Do i need to plug it in or will the molex plugins power it? 2: If i must plug it in, where do i plug it into?
-Made In Canada
https://linustechtips.com/topic/547790-gpu-fan-questions/#findComment-7238272
