I recently got a HG10 N980 from Corsair but the results are basically the same as when the card was air cooled plus it is bending my card ever so slightly. When I removed the reference cooler I never touched the thermal pads and I put the film that cover the pads on the HG10 onto the reference cooler'd pads. I'm looking to reinstall the reference cooler and I'm wondering if I would be fine without replacing the original thermal pads. Any feedback would be appreciated.
https://linustechtips.com/topic/547783-reusing-thermal-pads/
2 minutes ago, Xeenos said:
Ty guys. I have one more question, if I were to replace them what thickness should I go with?
I would have a look at the old pads and try to gauge the thickness, try finding one that hasn't clamped down on the edges but I think they're something like 1mm or something but don't take my word for it.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/547783-reusing-thermal-pads/#findComment-7240087
Ty again. I measured and it is 1 mm.
https://linustechtips.com/topic/547783-reusing-thermal-pads/#findComment-7240412
