Help me pick a monitor!
EPICvX
Hey guys, I want to buy a new monitor but I really don't know which monitor should I pick.
My first choice is a curved 27 inch monitor with 60Hz refresh rate and it is an IPS monitor so the response time isn't great.
My second choice is a 24 inch monitor with up to 144Hz refresh rate, it has 1ms response time but it is not IPS.
Those two monitors are about the same price (about $350)
I am doing a lot of gaming and a lot of image and video editing.
So which monitor should I pick?
yea, 144Hz is probably a TN panel. so the colors aren't great.
better colors + viewing angle goes to the IPS.
better response time + refreshrate goes to the TN.
the choice was easy for me. I don't edit photos/videos, just game/reddit. so TN for me :P
edit:
Rig specs?
i5, r9 380x
edit:
Rig specs?
Budget? I'd recommend you go for a monitor with 144Hz or 120Hz refresh rate. Save some money and get an IPS panel. You won't notice the difference. Curve not curved is a personal choice.
*thumbs up if it helps you :)*
IPS + 144Hz = $800 usd. if money is not a problem, go for it.
