my philips 200v4qsbr is ghosting like mad... what is going on  (everything is at factory settings)
My rig: r7 1700 @ 3.9/1.35v, 16gb ddr4 3200, assorted rando SSDs, hx 1050, vega 64 1650/1025
MY $75 BUILD https://linustechtips.com/main/topic/576889-the-75-build-log/#comment-7547280
https://linustechtips.com/topic/546810-ghosting/
Just now, R3DOPS said:
Ok. First of all try using the monitor on a different computer and see if you see any ghosting. Let me know what tou find.
I have 3 monitors (all different) and the others are fine (ish)
https://linustechtips.com/topic/546810-ghosting/#findComment-7228633
1 minute ago, R3DOPS said:
Ok Make sure you drivers are up to date. Next swap VGA or HDMI or whatever you use too hook them up and see if the ghosting switches to another monitor if it dose then its the cord.
nope...
https://linustechtips.com/topic/546810-ghosting/#findComment-7228652
