Just got blue screen of death, bad system cache. That's that's mean? My PC now takes minutes to turn on, unlike before, my CPU does not go above 6%. And unable to open most program's, wifi does not work anymore. When playing games before this happened my PC froze for a few seconds and make a buzzing sound out of the speakers. This also happened when watch videos. Any ideas???
https://linustechtips.com/topic/54681-help/
Have you recently performed a hard reset? (Hold power button until the system switches off). I've never come across this issue before so we'll just go over the basics.
Case = Bitfenix Prodigy, Motherboard = P8Z77 - I Deluxe, CPU = 3570k @ 4.2GHz, RAM = 2x 8GB G-Skill Ripjaws, GPU = Sapphire 7950 Boost Edition, Storage = 256GB Samsung 840 Pro.
https://linustechtips.com/topic/54681-help/#findComment-734824
Sure, yes I have
Did you perform a disk check when the computer was turned back on? If there was an issue then it would have come up after booting.
https://linustechtips.com/topic/54681-help/#findComment-734841
Yes I do
Alright, it sounds like a re-install of Windows is in order. It sounds like something may be corrupted, if re-installing doesn't fix the issue feel free to message to me and I'll look into other possibilities.
https://linustechtips.com/topic/54681-help/#findComment-734882
I'm not sure it's the os, it's a fresh install, it's about 5 says old
https://linustechtips.com/topic/54681-help/#findComment-734893
*days
Alright if you don't mind posting your rig specs it would help alot.  :P
https://linustechtips.com/topic/54681-help/#findComment-734905
