I need a 360 rad but I have clearance issues, so I was wondering can you mount normal 25mm thickness fans externally in the front? Like on the side with the grill. Would it close? Thanks :)
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/546366-air-540-users-help-pls/
3 minutes ago, Superspeed07 said:
I don't think it would close, there is an air filter then it is the grill/ mesh.
 Found someone who did it, but the filter is removable
https://linustechtips.com/topic/546366-air-540-users-help-pls/#findComment-7224180
