What is the best PSU for a low price at 500w and 80 plus preferably silver or gold
"The ability to destroy a planet is insignificant, next to the power of the force"
Kirito (Main Build):
CPU Intel Core i5-6600k OC'd @ 4.6 GHz Motherboard ASUS Z170-AR RAM 16GB Corsair Vengeance LPX 2400 GPU ASUS STRIX 1070 Case Phanteks Enthoo Pro Storage Samsung 850 EVO 250GB, WD Green 2TB & Travelstar 1TB PSU Corsair CS550M Cooling Corsair H110i GT Keyboard Razer Blackwidow Chroma Mouse Razer Naga Epic Chroma Sound Sennheiser HD280 Pro OS Windows 10
Asuna (My Laptop): Razer Blade Stealth
CPU Intel Core i5-7200U w/ Hyperthreading RAM 8GB Hardwired into the system GPU I N T E G R A T E D   G R A P H I C S  Storage Samsung 960 EVO m.2 120GB Cooling Fans yo Keyboard Razer Blackwidow Chroma Mouse Razer Naga Epic Chroma Sound Sennheiser HD280 Pro OS Windows 10
Yui (My mini server):
TBD
https://linustechtips.com/topic/546357-best-low-price-psu/
Could you define "low price" please? Also a currency and location would help. Prices and availability can change significantly for different locations.
Also, I'd focus more on the quality of the unit than the efficiency. Unless you're buying a load of them for multiple systems, you're not going to save a whole load on power between a 80+ Bronze 500W compared to 80+ silver or gold.
https://linustechtips.com/topic/546357-best-low-price-psu/#findComment-7224004
$50-100USD
And the thing is, bronze psus tend not to be modular and i would like a modular psu
TBD
https://linustechtips.com/topic/546357-best-low-price-psu/#findComment-7224034
I have seen this one, http://www.newegg.com/Product/Product.aspx?Item=N82E16817438053
I really do not like to buy cheap PSU's remember they power everything in your system, if they power it they can fry it, cheaping out on a PSU in the long run could end up costing you a new mobo, CPU, RAM, HDD, SDD, GPU and fans all the things you have in your system.
Remember a CPU may cost you $100, you save $30 on the PSU, thats nice. Then the cheap PSU fry's your CPU, that $30 you saved just made you buy a new CPU and a new better PSU, you really didn't save anything, it cost you a whole lot more in the end.
(I know better PSU can fry things but that dosn't happen that often)
https://linustechtips.com/topic/546357-best-low-price-psu/#findComment-7224122
