Argh how does this thing work
Solved by rEaGeNeReary,
18 minutes ago, wra2000 said:5 minutes ago, wra2000 said:This is the output : Parse error: syntax error, unexpected '$start' (T_VARIABLE) in C:\xampp\htdocs\index.php on line 46
Where do i have to excevute/paste that?
I know i am a noob
Put some effort on debugging it. There's a missing semicolon before the $start variable.
I won't hand-hold you; use google or something.
