Wtf Avast Firewall? Help?
Go to solution Solved by noisebomb44,
3 minutes ago, B.Toast said:
Yes, I am using a legit copy (sometimes I forget that people actually pirate things anymore).
...holy crap I think I fixed it.
I had to go in and tick "friends" next to my home network (which is set to "private").
VERIFIED: That fixed it. What the actual frell, Avast.
np, mark the thread solved to help people with the same problem
My Avast firewall is being a pain in the arse and not allowing certain things to connect to online services like they should. I've made a video displaying the issue. If anyone has any pointers on this, that would be great. I've tried uninstalling and reinstalling Avast as well, and nothing has changed. It is not having this issue on my other Avast installation, on my other computer.
If what I'm posting has already been posted, I'm sorry.
https://linustechtips.com/topic/545833-wtf-avast-firewall-help/
application rules - > something like "add a new program to pass through firewall" -> profit
Ive not used avast in years, but this is how you do it in most firewalls
You are using a legit copy, right
If yes, then try doing "run as admin"
Ive not used avast in years, so im not sure if this feature excist, but, if there is an adapter tab, where you can designate what security level each network (like your home network, mc donalds wifi, etc) has (office, public ,etc) try setting it to private/trusted network or something
Long live Stalin, he loves you; sing these words, or you know what he’ll do!
https://linustechtips.com/topic/545833-wtf-avast-firewall-help/#findComment-7217787
Not working.
https://linustechtips.com/topic/545833-wtf-avast-firewall-help/#findComment-7217808
Ive not used avast in years, so im not sure if this feature excist, but, if there is an adapter tab, where you can designate what security level each network (like your home networ, mc donalds wifi, etc) has (office, public ,etc) try setting it to private/trusted network or something
https://linustechtips.com/topic/545833-wtf-avast-firewall-help/#findComment-7217911
https://linustechtips.com/topic/545833-wtf-avast-firewall-help/#findComment-7217939
